YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Where is the plug to Read codes with The Code Reader (https://www.yotatech.com/forums/f116/where-plug-read-codes-code-reader-144258/)
simpsons721 May 3, 2008 05:01 AM
hey
i have no idea where you plug the code reader in a 94 4runner just wondering so i can diagnose some problems
bigt May 3, 2008 05:08 AM
actually you jump a terminel in the diagnois port and you count the check engine blinks..has a built in computer ill look up what ones to cross
simpsons721 May 3, 2008 05:12 AM
will the people at autozone do this for you??
bigt May 3, 2008 05:14 AM
no you can do this its so easy man..
get your self like 2 inches of wire... strip both ends
now open your hood.. look to the left above batter where you see diagnois.. flip up the black cap and put your wire in T and E now turn the car over to on but dont start it and count the blinks!
js9924 May 3, 2008 06:25 AM
the terminals you jump are actually TE1 and E1 the box is right next to the fuse box probably behind the battery it does say diagnosis on it. There is a drawing of which terminal is which on the inside of the cap. Then put key to on and count the blinks.
mt_goat May 3, 2008 06:53 AM
They will if your vehicle has OBDII, but that didn't start until 1996.
More on that:
http://www.obdii.com/
