Wheel Bearings
I am looking to replace my wheel bearings all front and back bearings but am having trouble finding all the parts numbers, i was going to order from the site below but they don't list a rear axles option so i was hoping to get parts numbers to send them.
http://www.toyotapartsales.com/partl...&siteid=214074 |
Are they shot or are you just doing it as preventative maintenance?
They don't normally need replacing. |
my front drivers side is shot and my rear passenger side seal is leaking, thought i should just replace them all if i had to do one, I was also told that if the seal is leaking there is a good chance the bearing is going to be bad.
So i should just replace the rear seals and not the bearings then and the one front bearing? |
Just know doing the rear wheel bearings can be interesting if you have never done it before.
Also a press comes into play If I remember they were not cheap!! |
Here ya go: https://www.yotatech.com/forums/f116...-today-230976/
There are pics there that show the Toyota part numbers. |
Cost me about 35 bucks to have a bearing pressed in and out, and i got a new timken bearing and seal for the rear that cost around 45 total iirc..
I got the complete rear axle rebuild kit when it went on sale from marlincrawler.com
