What does this VSV do?
When I ground the wire on the temp switch (Circled in blue) the VSV (Circled in red) clicks. Question is, what does this VSV actually control?
https://cimg6.ibsrv.net/gimg/www.yot...d2dd958a51.jpg https://cimg8.ibsrv.net/gimg/www.yot...533569d6e7.jpg |
That's the vacuum solenoid valve. In a few words If it doesn't work right the idle will be errant.
For more details: https://www.toyotaguru.us/engine-con...sc-system.html |
Yea, I know how it works but where does it hook to? I believe the other one in the lower left corner of the pic is the one your article is referring to. Or do they both just create the idle up? One (circled) temp related and one for extra load like lights etc? Not sure why I'd need extra air for either normal operating temp or low temp. (Depending on which way it operates. [normally open or normally closed] I haven't checked to see which it is.)
Check out page EC-19 in the link below.
https://cardiagn.com/emission-contro...86-89-4runner/ Cheers |
Originally Posted by Mr. Z.
(Post 52445197)
Originally Posted by rattlecanpaint
(Post 52445206)
This is what I was looking for! Thank you! This truck has had the reed valve removed so it is not needed.
The TSW (temperature switch) is what tells the ECU to toggles the FPU (fuel pressure up) wire to that VSV. It switch's the fuel pressure regulator's reference line between intake and atmosphere. I've covered this quite abit. It's an interesting and important part of the system. |
Originally Posted by Co_94_PU
(Post 52445231)
Disagree!
The TSW (temperature switch) is what tells the ECU to toggles the FPU (fuel pressure up) wire to that VSV. It switch's the fuel pressure regulator's reference line between intake and atmosphere. I've covered this quite abit. It's an interesting and important part of the system. However, Like Co says, VSV either exposes fuel pressure diaphragm to atmosphere (higher fuel pressure) or to vacuum (lower FP) |
All i can add is that I had to replace the VSV solenoid on my 3vze to fix some random idle surges I used to have. Per my understanding the VSV functionality is driven by Engine speed (Ne) Coolant temp, (THW) and Air conditioner clutch (A/C).
Originally Posted by Killemall
(Post 52445269)
(Post 52445266)
I haven't checked exactly what that TSW does. It thought it is to shutdown AC when coolant gets too hot.
However, Like Co says, VSV either exposes fuel pressure diaphragm to atmosphere (higher fuel pressure) or to vacuum (lower FP) https://youtu.be/_8ExdSIIDsc |
(Post 52445274)
A VSV is a "vacuum switching valve", there are various configurations of outlets and colors and they all control different things.
(Post 52445304)
You are referring to what the VSV controls,. I was referring to what controls the VSV. The 3vze has one VSV. and the solenoid opening/closing is triggered by the ECU based on the inputs it gets from Ne, THW, AC.
(Post 52445300)
When I ground the wire for that temp switch, that blue VSV clicks, so they're definitely related. I guess I could warm the engine up and find out at what temp that switch closes to be sure. I know there are (according to the wiring diagram in the Haynes manual) 2 temp switches. One I think was 30º C and one was 50º C. But again, who knows where each is located and if its even still there on this particular truck. I can definitely see the need for higher fuel pressure when it's cold and the CSI is running. According to the Haynes manual though it looks like the fuel pressure regulator is just plugged into that triple vacuum port on the back of the intake? I don't know. It's hard to follow because of the way they drew the picture.
(Post 52445314)
... scope will correct me, there three more mounted on the right hand fender apron (AS, FPU, and EGR).
(Post 52445300)
The Fuel Pressure-Up is not for cold starts; just the opposite. It's to address vapor lock http://www.cygnusx1.net/Media/Supra/...taTech/h22.pdf (page 9), and activates after hot soak due to higher temperatures. Just so you know.
Originally Posted by wallytoo
(Post 52445324)
the CSI doesn’t really run like the other injectors. it is only spraying fuel when the key is in the start position and the intake air temperature is below a certain threshold. once the key is released to the “on” position, the CSI no longer sprays fuel, regardless of temperature.
Originally Posted by scope103
(Post 52445325)
| All times are GMT -8. The time now is 11:42 PM. |
