what to do about A/C not working?
1986 4Runner 22re 5spd.
The A/C was not working when I got the truck and since I had so many things to fix, I concentrated on necessities first. But I really would like to have it working as we get some very uncomfortable humidity in the summer. Here's the status: + All the parts are in place and accounted for. + The A/C would do nothing when I attempted to turn it on. The "A/C" switch lights up. + When I put 12V directly to the compressor last night, I get a strong click. I think the solenoid works. + Grabbing the hub of the compressor and turning it moves well and feels OK. Not seized. + When I pushed in on the schrader valve with my fingernail, I can see there is some pressure present in the system + Some previous owner was doing research on the A/C system as is evidenced by a Haynes service manual I received with the truck and some notes. + I found some what appears to be O-ring kit for the A/C in the box of spare parts I got with the truck. Looks unused. - the idle up vacuum switch had a broken nipple and I fixed that, but testing it with 12V I get no action so I think it's bad. - I don't know for sure if the system still has R12 in it or R134(doubt it though) Any way to test? - previous owner did no work on the truck himself as far as I can tell and I don't recall discussing A/C with him other than maybe it wasn't working at the time of purchase. I could buy a can of R12 off ebay and see what happens, or do the whole conversion to R134 but I haven't been deep into an A/C system before. Only done recharges on Daily Drivers. I know you are not supposed to mix the refrigerants and oils. What would you guys do ? |
If a R134 conversion has been done by a professional shop, adaptor fittings standard for the newer refrigerant should have been left installed on both the high pressure and low pressure service ports.
If it was mine and still original, I'd keep it R12, but then, I still have a substantial stash |
my A/C system seems to be very different from yours. I do not have any of the mentioned parts, and it is turned on by opening the small triangular windows in in the forward area of the doors
Originally Posted by keycw
(Post 52424064)
Originally Posted by millball
(Post 52424063)
If it was mine and still original, I'd keep it R12, but then, I still have a substantial stash Can you think of anything else I can do by way of observation or test to determine if the system is usable? |
Originally Posted by Melrose 4r
(Post 52424074)
Ah! good point. No "different-than-original" fittings are present.
OK, just found out the oem A/C vac switching valves are still available from 22re performance so I just ordered one.
Recently acquired a vac pump so I'll have to figure out how to apply it to this. |
Aren't vacuum and pressure interchangeable in this case?
I'd probably tackle the electrical first and see if I could get the AC amplifier (AC brain) to activate the clutch wire. It needs an RPM signal, a pressure switch signal and I think one other signal I am forgetting. These are all listed in the AC diagnostics with thier inputs. It could be as simple as someone twisted the AC rpm cut off knob. |
(Post 52424064)
(Post 52424075)
First thing to is draw a good vacuum on it and see if it holds.
Originally Posted by Co_94_PU
(Post 52424080)
(Post 52424079)
Recently acquired a vac pump so I'll have to figure out how to apply it to this. The cheap and easy recharge method is to do like you mentioned earlier and just use one of the off the shelf recharge kits. The best way for you to proceed would be to find the pressure switch (locks out the compressor operation if you have an inadequate refrigerant charge) and check the wiring schematics or troubleshooting guide to determine if the contacts are open or closed with a meter and see if they are supposed to be open or closed when the pressure is low. If you determine that you have a low charge it is almost guaranteed that you have a leak, no telling how bad or where, but you can do the recharge and see if it works and for how long. A good shop with an A/C charging station and leak detection can take a lot of mystery out of it and in my opinion is the right thing to do so you don't just waste refrigerant. |
(Post 52424062)
+ When I pushed in on the schrader valve with my fingernail, I can see there is some pressure present in the system ... The A/C idle-up has nothing to do with whether A/C gets cold (it just inches up the idle when the ECM commands the compressor to start). Worry about that later. While it seems unlikely given the history, you might have sufficient refrigerant charge. You could try putting 12v to the compressor clutch with the engine running (without idle-up, you might have to open the throttle slightly to keep it from stalling). If you can get cold air within 30 seconds, the charge is okay and your problem lies with the electronics. Don't waste too much time on this; if the refrigerant charge is low that, by itself, will keep the ECM from commanding the compressor to start. IF you have any charge at all (it sounds like you do), then you can't work on finding a leak until you get that evacuated. So I'm with akwheeler; you should just break down and take it to a shop to get it evacuated. They might be able to quickly tell you what's wrong. If, after you learn what's wrong, you end up doing your own repairs, here's all I know about A/C: https://www.yotatech.com/forums/f116...-r134a-284801/ |
I have the same A/C system that was developed for the 1924 Hupmobile. The 260. I have A/C parts from a junker in a Rubbermaid tote with the intention of installing them someday. Subscribed to see how this plays out. IIRC if you convert to the new coolant you're supposed to change all the O rings to the green ones and replace the drier.
I converted the AC compressor in my '87 to onboard air.
Puts out as much, or more air, than my 5 horse Speedaire at less than 2000 revs. A few pics in a couple posts page 277 of the ' What did you do to your rig today' thread. |
Originally Posted by scope103
(Post 52424180)
That's a good way to get blinded. Also, you're wrecking the ozone layer and giving all of us skin cancer. Please don't do it again.
The A/C idle-up has nothing to do with whether A/C gets cold (it just inches up the idle when the ECM commands the compressor to start). Worry about that later. While it seems unlikely given the history, you might have sufficient refrigerant charge. You could try putting 12v to the compressor clutch with the engine running (without idle-up, you might have to open the throttle slightly to keep it from stalling). If you can get cold air within 30 seconds, the charge is okay and your problem lies with the electronics. Don't waste too much time on this; if the refrigerant charge is low that, by itself, will keep the ECM from commanding the compressor to start. IF you have any charge at all (it sounds like you do), then you can't work on finding a leak until you get that evacuated. So I'm with akwheeler; you should just break down and take it to a shop to get it evacuated. They might be able to quickly tell you what's wrong. If, after you learn what's wrong, you end up doing your own repairs, here's all I know about A/C: https://www.yotatech.com/forums/f116...-r134a-284801/ Sorry to hear about your skin cancer. |
(Post 52424185)
Originally Posted by nervo19
(Post 52424183)
i have the same a/c system that was developed for the 1924 hupmobile. The 260. I have a/c parts from a junker in a rubbermaid tote with the intention of installing them someday. Subscribed to see how this plays out. Iirc if you convert to the new coolant you're supposed to change all the o rings to the green ones and replace the drier.
Thanks everybody for the input. I will check around but i don’t think i will be able to find a shop who will be willing to work with the R12 system without converting it. My theory is the system is simply low on pressure and not coming on because of that. So i will borrow a gauge set from a buddy and confirm and if that’s it just get a can or two of R12 off ebay and recharge it. The factory service manual shows the steps.
Thankfully, no one had hacked the electrical circuitry on my truck. So I replaced the A/C belt, idle up solenoid from 22RE performance and fan blower resistor(had no low) and after adding 1 can of R12 to the low side, the compressor kicked in and we had cold air! The second can I added had dye in it, not that it matters much. If it leaks it will be interesting to find out where, but at that point i will probably have to do the full update to R134(or whatever the next refrigerant they are coming out with is). For now, we have A/C! The vitals look good, the idle-up works, one tube cold, the other tube warm/hot and no bubbles in the sight glass.
