weird noise
i have an 88 pickup with the 22re but when i get the motor to about 3000 to 3500 rps it sounds like the fan is hitting something. there is no check engine light and as soon as i get above that point it is fine again. i checked the oil fan and there is no damge.
Oil fan? Do you mean the cooling fan?
maybe i should invest in an oil fan too!!!
i am a dooms day persons, so i say timing chain. did they sell you some muffler bearings to go with the oil fan. :think:
i replaced the timing chain less then 10k ago should my fan wobble at all when i rev up the motor it moves maybe 1\2 an inch.
My waterpump was apparently loose when I first got my truck. Turned out to be hitting the fan when it came on. Just a thought.
i will look in the morning when the sun desides to come back up
If your fan is hitting the fan shroud under hard acceleration then you need to replace you motor mounts.
Originally Posted by tortis
(Post 50644576)
it has somthing to do with the power steering pump bracket cause if i put a pry bar between that and the header and pull a little bit it will stop. in the power steering bracket how many bolts hold it to the block?
Motor Noise
Originally Posted by yota_dude
(Post 50644834)
And previous post is right as well , if your motors mounts are broken or heavily worn it could be that as well |
Are you low on horn oil too? sorry had to do it. look at your fan shroud, if the fan is hitting it at some point, there will be some evidence there..
Originally Posted by ssupercoolss
(Post 50649699)
wow you guys are really mean he has a real problem and from being really tired just like me messed up on one word just like me and everyone gets on him for it dude i hate to say it but i had the same but mine was a lower end knock and a very lose chain take the valve cover off and see how play is in the chain mine had about 2 to almost 3 inches of play then it locked up woo whoo new motor with a heavy cam coming soon!!
Clutch Fan Wobble
(Post 50644834)
| All times are GMT -8. The time now is 05:06 AM. |
