Weird Code 51 and 52
Alrighty, I'm a long time puller from this site, but few and far between poster but I need ya'lls help with this one. My CEL has been on for years, ever since I bought the truck back in high school (88 4Runner 3.0). I never thought much of them as the truck had always run fine; I.e. Idle is 800rpm, a/c works fine, plenty of power (Even for the 3.0) up hills and at 7220 feet up here in Wyoming where I go to school. You can smell from the exhaust that she does run a little rich, but I still average 20+mpg. But now I'm determined now to fix the CEL.
I just crested the 250k mark and thought it was time for some maintinence. Last week (in an apartment complex parking lot no less) I just replaced the timing belt, cap, rotor, water pump, thermostat, upper idler pulley, tensioner pulley, valve cover gaskets, upper and lower intake gaskets and all new 200+ miles of vaccum and cooling hoses all the way around. While I had the lower intake manifold off I checked out the knock sensor because I knew it was throwing a code. It seemed ok, but the wire going to it was torn up and the insulation was melted. I did as other threads suggested and re-wired it with some heavy insulation wire to minimize noise. After that, everything went back on just fine and after a slight timing adjustment, the truck runs just fine like it used to. But I'm still throwing those two codes. P.S. the TPS was replaced 3 years ago, and MAF was replaced 8 months ago. Now, here's the weird part. When I start the truck, the CEL is off. It won't come on at idle. In fact, it won't come on during reverse or 1st gear. I could red, line it in 1st gear and it would stay off. But as soon as I shift to 2nd and even slightly engage the clutch, it comes back on. It still is flashing me a 51 and 52. I'm at a loss as to how shifting from 1st to second could do this. There's no mention of this on any of the other code forums I've read through...and I've read through a lot. If you have any tips please throw them at me! |
Check out the knock sensor (52) threads. The code comes on at a certain vehicle speed
Once again, I'm sorry to beat a dead horse, but all the 51 and 52 threads make no mention of this. It also does not depend on what speed I am going when I shift.
interesting... even like a rolling 1000 shift?
are you clearing the codes before reporting you see the CEL again? |
It's an automatic ? Or stick? I have no experience with code 51. But 52 is a tricky little bug. It can be quite a bit of different things. There is a lot about it in other threads. Starting another wouldn't accomplish much. Just read about it. Code 51 anyone? I have no clue
The pigtail that goes to the knock sensor(the wires you replaced) need to be replaced with a Toyota harness. If you go that far, you should just put a Toyota sensor in it too. Problem solved...... the Toyota harness is like 20 bucks
Yes, even when I reset the CEL, it still throws it at me when I shift from 1st to 2nd and I get a 51 and 52 without fail. I think in order to solve the knock issue Im going to do what this video shows. Pretty ingenious really. Let me know if you think this is a good idea.
That's a really interesting solution for that issue...looks reasonable.
somebody did the S10 knock sensor to mine before i bought it.
the light doesn't come on & doesn't give a code. although i'm not sure why he had to run an extra piece of wire to do it rather than use the existing wires :/ |
::::::takes coffee and dumps it on the key board:::::::: another knock sensor thread is born
::::::football spikes the phone to the cement::::::: |
Originally Posted by Trents3.slow
(Post 52339358)
Originally Posted by robertd33
(Post 52339321)
it is right above the middle spark plug.
a socket/extension bumps on it while removing the spark plug. |
Originally Posted by NapoleonDy2nite
(Post 52339368)
Sorry man. I didn't mean to start another huge one. I know theres hundreds out there, I was just curious to get ya'lls take on the correlation of the CEL coming on with the shift to second. I haven't found anything on that. I think (just by pure logic and guessing) that its coming on because when I shift to second, the ECU is getting a funny reading from somewhere in the engine - maybe too rich, maybe too lean - and its tripping the TPS system. I think the knock sensor is just a by product thats been there for years.
| All times are GMT -8. The time now is 05:59 AM. |
