YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   W56b reverse gear (https://www.yotatech.com/forums/f116/w56b-reverse-gear-320580/)
double Dz Mar 24, 2026 10:47 AM
W56b reverse gear
Going to be doing a clutch replacement so its probably the best time to replace my Reverse Gear.
does anyone have the part number that is not discontinued? What other parts are easily replaceable or part of the reverse idler, is the gear itself on a bearing or do i need to find a bearing?
if no luck on new parts let me know if you have a spare reverse gear for a 86 4runner w56.
Robert m Mar 24, 2026 02:37 PM
Not a lot of people around here dive into transmissions. You might find some threads about it with a bit of searching and there are probably some youtube videos on it
millball Mar 24, 2026 03:31 PM
Oughtta be a lot more bearings and wear parts like syncro rings changed when a tranny is opened that far,
Your reverse gear got broken teeth??>> There may be trouble in the gears it mates with as well.
