77RogueRunner |
05-18-2010 02:18 PM |
Vibrations at slow speeds, shifting into 1st & 2nd
Been driving my 88 Runner around recently with the 3.4 mated to the R150F r/h drop tranny and some weird stuff is happening. Used a new t/o bearing for the year tranny (95), kept the 3.4 clutch and related stuff, used pilot tool, etc. Weird thing is that it get some nasty vibrations when starting in first, accelerating and shiffting to second and accelerating. They diminish the faster I'm going. After I get up to 3rd and up to speed (50+miles per hour)the vibrations are almost un-noticeable. I remember when I was doing this swap I had to let air out of the tires(firestone M/t) for the body lift cause I was limited to the height of my work area. Could my tires sitting at 20-psi for a few weeks with the weight create a flat spot? I drove it about 20 miles round trip and they vibes were still there when I came back and slowed down. The only other thing I can think is I got a bad tranny. If I'm going down a hill and I let off the gas just enough to feel like I coasting, a blarring, kinda rotating scrapping sound is heard, alternately if I'm going say 50 on a flat surface and push the clutch in to coast, I hear the same noise. Anybody have an idea what this might be? I'm gonna take the inspection cover off but I can't really see past the plate. The vibrations are consistent with the speed, not engine rpms. Would there be something in the tranny or t-case that as it speeds up (output shaft?) would kinda align itself from the centrifugal forces? The tranny was a dune rollover so I'm hoping a driveline didn't get smashed or jammed in the process. Thanks...D
