Turn signal flasher location - HELP!!
I've spent the last two hours on my back under the dash of my freshly rebuilt 92 PU trying to find the d!!!! turn signal flasher and cant find it! this is the only thing keeping this "new" truck from hitting the pavement. Left rear turn signal isn't working and the flasher is the last thing for me to check. Please help fast, I'm about to set the truck on fire.
There is a fuse box inside the cab, the turn signal flasher is plugged into that fuse box.
Assuming the 92 is similar, this may help:
http://www.ncttora.com/fsm/1993/body.../4lighting.pdf Looks like driver side under dash or driver side wheel well kick panel. |
Hmmm... no answer?
Wonder if the house burnt down with the truck? |
turn on the 4 way flashers , and follow your ear
