turbo rebuild help
I just finished rebuilding my 86 turbo engine. I got it running and it starts fine and revs good but cuts out at 4500 rpm's. I checked the timing a few times, new tps, checked the maf, all injectors are plugged in, alternator is on but still cuts out. There is no coolant in the engine yet so I dont know if it has an ignition sensor of some sort without water or what. I have 2 injectors that leak fuel, but im not sure if that would be the prob. Does anyone have any ideas what this could be? Thanks for the help.
Derek |
Is it warmed up? Mine would do that if it wasn't warmed up. Plus PUT COOLANT IN THE ENGINE ALREADY!
:D |
2 injectors leak? That would do it.
