Trouble finding throttle cable for 88 pickup. Help!
I've been calling around and no one carries them anymore! Toyota part # 3552035080
It's a 22re 4 cylinder
:coffee:
Does your truck have an automatic or manual transmission? Is your truck a 2-Wheel drive or 4-Wheel Drive vehicle? Which throttle cable are you looking to replace? The one going from the accelerator to the throttle body or (if you have an automatic) the cable that goes from the throttle body to the transmission? A little searching with that part number shows that part is the automatic transmission throttle cable (from throttle body to transmission, not to accelerator pedal) for 2-Wheel Drive Trucks from 1986-1988. That particular part number has been discontinued. :( :safari: |
Yes, automatic and from gas pedal to throttle body. Anyone know if another year or part number may fit?
For the cable that goes from the accelerator pedal to the throttle body, it looks like this part number comes up:
WIRE ASSEMBLY, ACCELERATOR 78180-89141 I would double check that with your favorite dealer or online dealer with your VIN to verify. OR You can contact 22RE Performance and verify: 22RE Performance Throttle Cable :safari: |
