Trans Oil Temp Light Came On
Trans Oil Temp Light Came On-OD Switch Question
Last night while driving from Palm Springs to Banning (slight uphill grade) my trans oil temp light came on. I pulled off the freeway for a short while, the light went off, then I continued home with no issues. Maybe it was my fault because I didn't turn the OD off. I know when the trans is in overdrive and you go up a grade, it downshifts (or slips) causing the engine rpm to go up 500 rpm or so. My question is, do I need to turn off the OD every time I drive up a grade? What is happening in the trans when it downshifts in OD?
Specs- 91 4Runner 3.0, 152k mi, auto, new engine, new radiator, vehicle new to me.
09-04-2015 09:27 AM
Poncho0206
07-10-2015 06:21 PM
