YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Toolbox CB Mount.. (https://www.yotatech.com/forums/f116/toolbox-cb-mount-157895/)
Trustyrusty Oct 29, 2008 10:03 AM
Toolbox CB Mount..
Anyone know where I can get a mount for my CB Antenna (4' Firestik) to mount to a toolbox? I took my rollbar out cause it got in the way and I need a toolbox more than that.. So I'm putting my toolbox back in but neet a mount for my CB antenna cause my antenna is rail mounted..
andtheman1988 Oct 29, 2008 10:06 AM
Radio Shack has them, or check at your local truck stop they should have everything you need.
ryantowry_81 Oct 29, 2008 10:07 AM
i have always used the clamp on mounts they use on semi trucks and loose the backing plate and just drill four holes in the box, always worked well.
Trustyrusty Oct 29, 2008 10:23 AM
Aight.
georgiayota Oct 29, 2008 10:32 AM
I have mine mounted on a piece of 2in square tubing that i bolted to the toolbox. I bought one of those rail mount L brackets and bolted to the square tubing. I use the square tubing because you want the antenna to be atleast an inch and a half from any metal.
abecedarian Oct 29, 2008 12:54 PM
the clamp on with the four bolts drilled on a vertical surface is probably the most stout solution you'll find. the mounting stud, where you just drill an appropriately sized hole and through-bolt it on are good only with thicker metals since the antenna will whip around while you drive.
Jay351 Oct 29, 2008 01:56 PM
Just a note, I read in the FSM that you should keep componants for a CB radio as far away from the ECM as possible..
Trustyrusty Oct 29, 2008 03:20 PM
Thanks Jay, but thanks for (RUBBING IT IN MY FACE!) that I don't have EFI.. I wish I had EFI, but then again I've never had any carb problems..
abecedarian Oct 29, 2008 03:23 PM
bet you have an ecu though. ;)
Trustyrusty Nov 1, 2008 11:09 AM
Find it for me then! Haha I'd rather not look. :bigok:
Jay351 Nov 1, 2008 01:40 PM
Well then, giver! :D
