YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   timing problems (https://www.yotatech.com/forums/f116/timing-problems-259136/)
AWeissert Sep 22, 2012 09:03 PM
timing problems
using a jumper & timing light, I set the timing to 5 dgrs. But with the time set like this the engine bogs and or dies whenever i hit the gas. the ecu only shows the 51 code. I had to set my time back to 36 dgrs for any sort of acceptable performance. Could my distributor be the problem?
sechott Sep 22, 2012 10:34 PM
Code 51 usually means your TPS needs adjusted, this usually means your computer is not getting the idle signal. Easy job if you have mechanic skills, Haynes manual and a set of feeler gauges. Get this worked out before suspecting bad parts.
