Timing Idler water out let pulley #2
#81
if you have a good quality 1/4" drive, you should have no problem removing the bolts, the torque is just minimal , probably just tight because of the old thread locker from factory or from rust.
be patient and and you will get!...
#82
thanks tnrabbit*** pulling the left and right cam to the right a little to get the slack out really helped- after 2 weeks of working on it a little before work and after work finally got it all buttoned up with no leaks and only had to put the timing belt on once to get it right - i love this site, never been into the blogs or forums but I've learned more in the last month about my truck than any other yota I've owned.... : D
#83
x2 on tearing out the gasket that comes pre-installed on the no 2 idler pulley and using Toyota FIPG
I've had two separate incidents of leaks from that joint - last time I put some FIPG in addition to to pre-installed gasket. This time I scraped it clean and am just using FIPG
#85
Hey buckz6319, your write up seems extremely helpful and a lot of good tips in the thread. Would you still happen to have the photos available as they seem to have disappeared.
Thank you,
Stefan
Thank you,
Stefan
#87
Avenged
07-09-2015 07:55 AM
