Tech help
Old Jan 11, 2016 | 04:15 PM
yoyo911's Avatar
Tech help
I am needing some technical advice from someone. I have a 92 Toyota 4Runner with the V6. Cranks and runs beautifully in park and neutral at both cold temp and at operating temp. Will shift fine until it gets to operating temp., then kills the motor. Anyone got any ideas?? Thanks in advance.
Old Jan 11, 2016 | 04:41 PM
millball's Avatar
Torque converter does'nt unlock??
Old Jan 11, 2016 | 04:44 PM
yoyo911's Avatar
I think it does. I just put new shift solenoids and the torque converter solenoid in it today. It does perfect until it gets operating temp.
Old Jan 11, 2016 | 04:59 PM
millball's Avatar
Thats what I'm saying.
I don't think that the converter will go into lock-up until operating temp is reached, so you have relatively normal function until then.
After lock-up it may not unlock correctly hence: engine stalls.
The fact that this prob appeared after tranny solenoid work may be significant.
Old Jan 11, 2016 | 05:03 PM
yoyo911's Avatar
It was worse before I put the solenoids in it. Before I put them in, it would go dead putting it in reverse and drive.
Old Jan 11, 2016 | 05:04 PM
millball's Avatar
Still sounds like converter lock-up issue to me.
Old Jan 11, 2016 | 05:06 PM
yoyo911's Avatar
It got better after the solenoid change. Do you think it might continue to improve?
Old Jan 11, 2016 | 05:10 PM
millball's Avatar
All you can do is wait and see.
How many miles on the tranny??
Know any service or repair history on it?
Old Jan 11, 2016 | 05:12 PM
yoyo911's Avatar
It has around 180000 miles on it. Don't know the history on it other than a filter and fluid change not long before I got it.
Old Jan 21, 2016 | 12:08 PM
millball's Avatar
Any news on this??
Old Jan 21, 2016 | 12:46 PM
yoyo911's Avatar
It does good as long as you don't touch the brake pedal. Also has a throttle position sensor trouble code on it now.
b_stone81
Diesel Swaps
May 11, 2016 05:33 AM
Brandon H.
Nov 1, 2015 06:07 PM
twasabug
Oct 30, 2015 11:11 PM
yota884huntn2
Oct 27, 2015 12:16 PM
Notabout2try
Oct 13, 2015 11:48 PM
