tailgate hinge rattle
I just got an 87 4runner and noticed this crazy rattle in the back. After some investigation I have figured out that it is the tailgate hinges. Has anyone fixed this problem and what did you do?
I just fixed this problem on my 85 4runner. The place where the two hinge pieces are connected is loose but couldn't really fix that.
I fixed it by putting a couple washers on each of the 4 bolts that hold the hinges to the body and the tail gate. When tail gate is down, it will be movable and a little loose, but better than before. When tail gate is up, no more rattle. Just a few cheap metal washers on each bolt and it worked like a charm. Nice to have a quiet ride again :-) Hope this helps and fixes your problem as well. |
There's a cool new search feature here...check it out. :great:
There are plastic pieces that keep the hinges from rattling and they usually break/fall out with age. You can order replacements or come up with your own anti-rattle solution. |
I know there is a search button but you can't always find what you are looking for or easily so nothing wrong with posting up something hoping someone can be nice helping out like i did or post a link to where it was covered before possibly. I just get tired of people saying that about the search feature on any forum now because they do it with such an attitude seems like. Nothing personal BMcEL.
Originally Posted by 3YLSYKR
(Post 51871088)
:grouphug: |
I did a search under hinge rattle and came up with nothing. I just searched for tailgate rattle and found the info. Thanks!
All that I seen that was there before was some rubber washers that were kinda thick but had worn out over time. Either or will work.
(Post 51871088)
(Post 51871117)
here u go bro..some pics also...https://www.yotatech.com/forums/f116...=rear+tailgate
Originally Posted by RMA
(Post 51871154)
Nylon washers maybe?
But I'm sure you searched. ;) |
