tail light relay??
where is the tail light relay, is this in the fuse box ( brown looking from denso) it a 87 22r
next to the black one from denso?? i did something dumb:pat: i was tapping a bumper light single wire off of the factory two wire and grounded out now my tail light and dash lights dont work, headlight flashers ,brake lights work all fuses look good, and the only thing i can find from the hyanes book would be the tail light relay???? oh yeah if this is it how hard is it to get out |
Check the fuses again. Also check the fuses under the hood.
James |
:think: I checked all the fuses in the fuse box, are there any more??? in the fuse box i have a 80-good 30-good 40-good 7.5-good 15-good 10-good another 10-good, thats all i know of
The drivers kick panel, did you check there?
James |
no but i will remove the kick panel
coool thanks middle 15 amp fuse, now i can drive home( it will be dark when i get off work) and not look like the biggest cop magnet, like i did driving here at 4am
