suspension options
I have an 89 V6 runner that while pretty to look at drives like crapola. Im currently runing 33's no lift but a stiffer torsion bar and upgraded leaf packs in the rear. I didnt install these they came with the truck so I am not 100% sure of the brand etc but I do know it is not add-a-leaf. I feel like I am in a martini shaker a good portion of the time. The shocks look stock based on their lack of fancy color and size. They are def old so I cant tell much about them. Would new shocks calm the truck down. I want lift it and redo the susp entrirely but at the moment it isnt in the financial cards. So my question is would just a better quality shock help....or just make it stiffer? Wich is obviously not what I am looking for. Offroading is the least of my driving so take that into consideration I just dont do much wheeling so please dont tell me to SAS or anything goofy I am fine with the ISF setup. Thanks for any helpful advice guys
A cheap option you have is to install a bj spacer in the front and let the tbars out a little, and in the rear take out the aal's and go with an extended shackle...
That can be done for under $200 and will relax the ride some. If the shocks are worn you'll just be bouncing a little more than you should. New shocks will improve the ride if that's the case but that won't soften it up any at all, that's in the springs. |
Originally Posted by ovrrdrive
(Post 50608531)
Originally Posted by SKNKWRX
(Post 50608610)
Yea Im trying to decide if its the springs or worn shocks. unyil I can replace al the suspension Im looking for a cost effective option. I have thought about the bj spacers. they seem tricky to install.
Frank |
If your shocks are worn the ride can be horrible.
I just replaced what was likely stock 20 year old shocks on my 4runner with new Bilsteins and the difference is night and day. I went from a near kidney bruising ride to something that is firm although very well damped. Handling is much improved and I've really been enjoying my truck again. Well worth the $250 I spent on the shocks. It took me about 6 hours taking my time and cleaning things up as went to do the job. |
I may try new shocks and see if that helps then possibly the BJ spacer after that. My rear sits a touch higher as it is now.
One thing that will make the truck ride stiff regardless of shocks are the stiffer torsion bars. Also, post up a pic, I bet the suspension has been adjusted such that it is higher than stock to clear those 33's. Adjusting the front suspension for more lift instead of using, for example, a BJ spacer will very much stiffen the ride.
The BJ spacer is designed for 1.5" of lift and will soften the ride a bit over stock so they will help. If you do have the torsion bars cranked up excessively high, I would add a small body lift to clear the tires and bring the front suspension back down. You would need to post a picture or measure from the rim to the fender lip though for us to know for sure if you front end is cranked up. Frank |
Do the BJ spacers before you buy front shocks or you will have to do it twice.
Your ride will be much improved with BJ spacers and relaxed torsion bars. Robb |
