stock toyota p/u 2wd height? (measured)
Could someone that has a stock 2wd pickup measure the distance from the ground to say; the bottom of the doors?
Just got finished with my lift and I am curious how much higher I am. I was lowered 3" before; and never took any measurements so I can't base it off of my own stuff.. which i never had the chance to take |
my 2wd is right at 12" inch's
where exactly is that measured up too?
bottom of the doors, That's what you asked for right. i just went out to the garage to measure.
i mean; is that bottom of the door *like with the door open*.. where the body is. Just wanna make sure when I measure i get the same spot! Btw; thank you for measuring!
no problem dude, its from the very bottom of the body like under the door where the pinch weld is.
cool. I will go out and measure mine to that point!
