Speedometer Replacement Questions
Two years ago the cable broke, last year the speedo broke, and now the speedo went out again.
Anyways, last time I found a cluster from a truck with all the same options: manual, V6, 4x4. I can't find an exact this time. Does it matter? I know I have to find a mechanical gauge, but does it have to be from a manual, V6, 4x4? (Truck is a 91) |
Get one from a 89-91 4x4 v6 MT I can't remember if it was 92 or 93 that they changed to an elec speedo.
92 went electric.
Are you saying that engine, trans, and 4wd matter, or just that I should try to find one the same as mine, to be safe? |
Different engine means different trans. There was only one 5sp for the 3vze MT. It was the r150f.
Im pretty sure the cables where different.... I would find one the same to be safe, but hopfally sombody else will chime in with some guidence.. |
