Speedometer/Odometer
Old Nov 9, 2014 | 06:42 AM
bway4x4's Avatar
Hey guys,
Bought my first 4runner. It's a 92 3.0 automatic. I bought it with the speedometer and odometer not working, figured it wouldn't be a hard fix. Now I'm coming to you for some expertise.
I've done some research, although it seems it's hard to find viable information. I have removed and inspected the speed sensor at the xfer case, even bought one from a junk yard just to try. So far I've had no luck getting it to work. How do you troubleshoot these as it is a 3pin connection? Not sure the correct steps to take. Thanks guys.
Old Nov 9, 2014 | 06:00 PM
bway4x4's Avatar
Anyone?
Old Nov 9, 2014 | 07:11 PM
scope103's Avatar
I assume you have the electronic VSS1.
I have attached a drawing of the connector. The component is an IC with an integrated hall-effect sensor. You need 12v and gnd to power the IC, and the signal is 0 or 12v.
Since you've taken a chance on a junk unit, the first thing to do is to test it. Battery voltage can power it, and a multimeter can pick up the signal. The hard part is connecting to the pins of the connector, but it can be done.
On mine, I tested in the opposite direction, but you'll need a signal generator to do that.
Someone on this site reported finding the component filled with oil (bad o-ring). He cleaned out the oil, and the component started working again. I suppose it's possible ...
Attached Thumbnails Speedometer/Odometer-vehiclespeed1connector.jpg
_RaStA_RoCkEt_
Jun 10, 2017 03:41 PM
eleazar1
Jan 2, 2015 01:10 PM
ChefYota4x4
May 26, 2014 04:12 PM
fork
May 14, 2013 05:55 AM
Relyks
Aug 21, 2012 02:05 PM
