scope103 |
08-22-2016 11:32 AM |
The answer(s) depends on the year, transmission, and 2wd/4wd. Most likely, you have the electronic VSS1 which drives the speedometer, odometer, and speed signal to ECM. So, to get us started, is your speedometer working? If it is working, you likely have the "older" cable driven speedometer, where VSS1 is a reed switch inside the combination meter.
The transfer-case-mounted VSS1, can and does fail, but usually not until your rig hits 10-15 years old. Oh, right. RockAuto has the (aftermarket) part, but you may have to remove yours first to match the photographs. There are different units, and I can't tell you when and why, but they are different enough to distinguish using the photos. Removal is easy; there's a 3-pin connector, the unit is held in with a single bolt, and you rotate it (there's an o-ring that provides friction) back and forth to wiggle it out. Don't lose the nylon gear; the replacement unit won't have the gear.
