*SNAP* Rear Axle sheared off at 45mph and tire went for a ride!
#41
Looks like you need a new rear axle.
I broke my two clips getting them off my rear axles but I got new ones from the dealership for like $2. =) If the shop didnt have the right tools or jig to press the bearings on it's easy to not get them on all the way.
As for the full-floater conversion. It's expensive.
I just went with chromoly rears.
Also, you sure you didnt notice ANYTHING odd before the axle came out? With the excess runout on the that rear side you'd of felt pulsation in your brake peddle..
#42
No, notice the dust shield is still ont eh axle housing.
Was bearing failure or or C-clip failure for sure.
#43
edit.
The clip is at the end of the axle, not in the differential. You press the bearing on the axle far enough down to where a C-clip slids on into a groove that prevents the bearing from "un-pressing" itself. The only thing holding that axle onto the truck is the bearing on the axle and the bearing inside the bearing case which is held to the axle by 4 bolts. The clip keeps the axle from moving perpendicular to the bearing.
An very worn out bearing can cause axle run-out which can cause permanent warpage of the axle flange on OE axles. Which in turn wears out the OE differential. I can't imagine spline damage unless it got very severe but i dont think you'd be driving the vehicle at that point =p
#44
There are parts of the bearing still in there.
If the axle housing is fubar, and it were to be replaced, even with cromoly axles, this COULD happen again. The ~$1000 to go FF and disc brakes from FROR + the other parts you need to supply seems pretty cheap by comparison.
I didn't feel anything terribly unusual, just the rear end dropped down and I looked to the left and saw the tire passing us - it took a while to pass us!
#46
#48
Tacomas and 3+ gen 'runners have a semifloating front. If you have one, you MUST carry at least the outer stub of a CV to hold the wheel on if the CV breaks.
#50
tc, thats the wrong side of the axle. I said theres no clip on the differential end.
Could happen again? This is the first time I've heard of it happening on a toyota.
No one has said if the wheel-bearing was replaced? It would make a heck of a lot more sense if it'd been tampered with because this happening on a factory job could mean something TOTALLY else. Failure of the bearing? C-clip?
Molly said it has a detroit, were the bearings replaced then? The c-clip and bearing have nothing to do with a locker install unless you're servicing the whole axle.
#51
The axles DO have a C-clip.
edit.
edit.
#56
sorry they arent the best pics of what you wanted, but its as close as i could get!
full thread here
https://www.yotatech.com/forums/f2/replacing-rear-axle-seals-bearings-pics-110243/
full thread here
#57
Yes, it's a '93, but I think the rear axle is the same. I didn't really look at mine close when I pulled them to do the ARB's, so I'm not sure, but wouldn't there have to be a groove or something in the axle shaft for it to hold to?
WTF is that gear thing in the pix above? ABS resolver?
To make a long post a little longer - I don't trust a press fit like I do a solid mechanical connection like a FF axle has.
#58
there is a C clip that holds it together, and the bearing and restraining rings are are all pressed until they wont go any farther.
the gear thing is an abs exciter ring that they have to cut off (along with both reatainer rings 92$) in order to press the bearing on. the guy i took it to here in gainesville was referred by gatorland toyota, so hopefully he knew what he was doing!
to be honest with you, this was the first time i did this (bearings were replaced at 80k and i currently have 117k) and after seeing how it was set up, i dont know how much i trust it. dont even get me started on 4 tiny bolts holding my axle shaft to the axle housing thing... though i guess it has been fine for everybody else, so maybe i shouldnt worry abt it.
on a side note, both front axle seals are leaking so i need to find some info on how to replace those and get to that...
i love the smell of 75W/90
#59
If that is what you folks are referring to; that's not the C-clip that is being talked about (by me at least). That is a spring steel circlip or snap ring if you prefer. The C-clips I & others are talking about are not spring steel & do not require snap ring pliers to remove. I'm sure that's where the confusion is coming from, the Toyota has snap ring retainers, not C-clips. The C-clips we are referring to are named that because they look like a "C" it's not short for circlip.
Edit: thanks for the picture Gonzo!
