slider install?
When you guys weld your rock sliders onto the frame to you put a piece of plate between the frame and the round tube or just weld the tube to the frame? I'm thinking when I install mine I'd like to do some plating to distribute the stress when the slider encounters a rock.
Ideas? |
dont they come with those on trail gear ones?
absolutely put a piece of plate in between, and not straight up and down, but diagonally... <>, not []
gusset it with a diamond shaped plate with right angle pieces connecting the gussets and the plate.
check out dirtco's buildup... hes got pictures of the sliders he put on his runner, and the gussets and frame plates he used...
plate and gusset. for sure.
X7 !!!!!
Edit...: Wait, I thought you were trying to sell.:think:..That 85 fall through...? :dj: |
just weld the tubes to the frame. Works fine on mine. I have slammed them pretty hard of some rocks and trees and have yet to bend.
Originally Posted by scuba
(Post 50995548)
X7 !!!!!
Here's my slider install:
https://www.yotatech.com/forums/f31/...nstall-100157/ |
Originally Posted by BAMF_CT2004
(Post 50995652)
| All times are GMT -8. The time now is 05:26 PM. |
