YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   rolled on paint (https://www.yotatech.com/forums/f116/rolled-paint-95720/)
swerks Sep 26, 2006 04:51 PM
rolled on paint
[IMG]http://img146.imageshack.us/img146/4331/b1kw6.th.jpg
I rolled this paint on,:bigok: What do you think ????
Elton Sep 26, 2006 04:55 PM
looks pretty good ..... need more pics and some close ups
keithguts Sep 26, 2006 04:59 PM
looks real good to me, but really hard to tell by a pic. need some closeup shots for a good answer.
AaronW Sep 26, 2006 05:02 PM
Nice Paint!
Swerks,
did you see the '69 dodge challenger that was painted with a roller? I think I have the thread saved somewhere, but I'd like to hear more about your experience.
86SR522REEFI Sep 26, 2006 05:09 PM
what did you use. we need a write up. lol
AaronW Sep 26, 2006 05:09 PM
'69 charger with rolled on paint
Swerks,
I found the thread I was referring to in my previous post. If you haven't seen it check here:
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
trythis Sep 26, 2006 05:13 PM
Looks great to me. Even if is isnt perfect up close it is doing its job, and keeping the water off the steel.
swerks Sep 26, 2006 05:27 PM
If you keep clicking on the picture it should get larger. I did follow the procedure outlined in the 69 charger post on the mopar forum. its professional rustoleum paint (smoke grey ) took me four days two coats a day with eight hrs min. dry time between coats.
Figit090 Sep 26, 2006 05:48 PM
Originally Posted by AaronW (Post 998753)
Swerks,
OMG that's awsome!! i have a gun and air so i'd proabaly still spray but... the price!!!! its incredible!
could you spray this stuff? i read mentions of 30 bux a gallon or something? that's cheap i think...right?
AaronW Sep 26, 2006 06:22 PM
Question
Swerks,
Did you wet sand the paint between coats or did you just paint it?
AaronW Sep 26, 2006 06:28 PM
Self Leveling Paint
Figit090,
I read much of the thread, but not all of it. Anyway, the guy with the '69 charger was asked if the same or better results could be had by spraying the same paint instead of rolling. If I remember correctly, he said that spraying was not as effective because: 1) some of the paint never hits the car (Some is lost? I don't know I don't paint cars.); 2) spraying kicks up dust; and 3) the paint is self leveling so with using the high density foam rollers it should go down pretty smooth for a roll on job.
BTW, I like your Supra.
Figit090 Sep 26, 2006 09:24 PM
thanks man :D i should have new pics on my cardomain (link below) kinda soon...take a week or so though.
but anyhow.....
yeah for spraying its "atomized" and some of it will never make it to the spot you intend. if you do not cover the WHOLE car when spraying you can get paint flecks that float from one corner of the car to the opposite one at the other end of the car! all depends on air current probably..but it definitely doesnt get as accurately applied as painting.
i could see the roller being good if you took your time, with spray you can take many light coats and totally avoid dripping... but whatever...i would think both would look great.... and if i ever got a truck that needed paint i'd probably do the method used here :D sounds kinda fun.... and i have a gravel driveway so dust is a major concern in my garage. last time i did painting though i draped butcher paper around the car for a nice little sanitary area...lol.
swerks Sep 27, 2006 01:38 AM
I did do some wet sanding and the whole process was not so much fun after the second coat or so, but you cant beat the price.
CRamsey Sep 27, 2006 03:27 AM
Hey Swerks,
Did you roll the rear cap as well? Is that gloss black? Mine needs it bad. I'm thinking I'd go with semi-gloss black if it's available.
Thanks, CRamsey
91 4Runner Sep 27, 2006 05:23 AM
Nice job on the paint. I read the same mopar thread and it prompted me to do the same..
Sorry to hihack..
I sprayed mine in the wet grass my backyard. I wet sanded between coats 2 and 3 but haven't done it after coat 4 yet... You do need to do alot of masking off.... Today I'm going to wash it after wheeling it hard on the weekend (3weeks after painting - thinned to 1 cup mineral spirits and the rest of the 1 quart sprayer cup with paint) So we'll see how well the paint holds up after washing the sandy mud off.... You do only get 4 coats if you spray it (with very little left for touch-ups - maybe half a quart)
Here's a picture...to compair the 2 different methods
http://i93.photobucket.com/albums/l7...Picture006.jpg
I'll take one later to show how well it holds up after washing the sand off...
swerks Sep 28, 2006 02:11 PM
the cap is gloss black rustoleum
bruzer1123 Sep 28, 2006 04:06 PM
Nice job...I really dig it. I am in a similar boat (don't know how to paint, no compressor, etc.) and I think rolling on paint is awesome. I might need to do something to it in the spring (after all the salt-uh). Great job!
trythis Sep 28, 2006 08:37 PM
I think the benefit from rolling is you dont have to worry about overspray, you can paint a door, and go to lunch, then is you dont wanna paint for a week, you car issnt covering tape and paper, just drive it.
gohawks Sep 29, 2006 06:26 AM
how did you prep the fiberglass top?
CRamsey Sep 29, 2006 10:38 AM
Cleaning the fiberglass top...
I found a good way to clean the top. I had waxed it a while back. Once the wax dried I had a hard time getting it all off due to the texture of the top and it wound up looking very chalky. The remedy I found was to get a can of 3M Wax and Adhesive Remover spray from the Walmart automotive section, and some of those Mr. Clean Magic Eraser pads. They're like white sponges, maybe 3x5x1 inches. Spray the 3M stuff on, let it sit for a minute or so, then rub it real good with the pads. Damned if it didn't take all that old wax off. It's very clean now, but you might want to prep it a little more for paint. My .02....
