replacing upper ball joint
I have to replace the upper ball joint on my '90 4wd. I've looked at the fsm and it doesn't really say anywhere about supporting anything when removing the steering knuckle. Being that the upper arm is the one the torsion bar goes to..... is this thing spring loaded and going to take off like a missle when I loosen the ball joint, or can I remove the knuckle without doing anything to the torsion bars etc?
Thanks alot!! :bigclap: |
Originally Posted by jeepboyny
(Post 1005629)
ok that sounds great. thanks!
if thats under pressure its gunna shoot out like a rocket man
Originally Posted by CopenHagen_Smokeless
(Post 1005647)
One thing: you're gonna need a heckuva puller to get that BJ out of the spindle (I custom-modified a craftsman puller to work). Plan on it being a PITA, and a BFH probably won't do it... |
if its a spring its gunna be under ressure no matter what
:lol: Care to explain? The upper control arm will not be going anywhere if there is no load on it whatsoever.... i.e. resting on the bumpstops.... you know.... kinda what Mastacox said. Well exactly what he said to be precise.
Welcome to Yotatech btw. You'll find lots o help here!!:bump: Cheers, Lee Hathaway |
(Post 1005666)
it works like a spring only in that it resists upward travel by twisting when the front suspension travels up after hitting a bump or something!, but when you allow the a-arm to drop any load that was once on the torsion bar is not gone because it does not have to resist the twisting motion of upward travel. so no there will be no load on thoes bars and youll be all good once you jack up your front end jeep boy! |
A couple of tips from having replaced all of my balljoints recently and previously put on BJ spacers:
Before you jack up the front, put a small metal or wood block between the upper arm and the bumpstop that it will go against. This will allow you to get the wheel off without jacking quite as high, and give you more room to work. To get the ball joint taper bolt out of the the steering knuckle, put some pressure on the taper bolt (with a bearing puller, tie-rod puller or pickle fork), then smack the cast portion of the knuckle that surrounds the taper bolt with a ballpeen or claw hammer (not too big) a couple of times. Your blow should be at a perpendicular to the bolt. This will loosen up the bond between the taper surfaces. With the load from the puller or fork, the ball joint will pop right out. HTH |
(Post 1005666)
This is NOT a springloaded IFS but rather a rubber torsion. Pull your front tire and go have a looksie Just take off the tire, put the front end of the truck on jackstands, unbolt the shock, unbolt the four balljoint bolts and pull the BJ. Nothing is going to go anywhere even if you were to push the truck OFF of the jackstands or wail on it with an industrial jackhammer! And yes I know this for a fact as I personally unbolted the right front ball joint on my truck in this manner when I changed out my CV on that side..... |
Originally Posted by 86Original
(Post 1006454)
Before you jack up the front, put a small metal or wood block between the upper arm and the bumpstop that it will go against. This will allow you to get the wheel off without jacking quite as high, and give you more room to work. To get the ball joint taper bolt out of the the steering knuckle, put some pressure on the taper bolt (with a bearing puller, tie-rod puller or pickle fork), then smack the cast portion of the knuckle that surrounds the taper bolt with a ballpeen or claw hammer (not too big) a couple of times. Your blow should be at a perpendicular to the bolt. This will loosen up the bond between the taper surfaces and with the load from the puller or fork, the ball joint will pop right out. HTH |
Originally Posted by Bumpin' Yota
(Post 1006563)
so placing a big pickle fork btwn the steering knuckle and the balljoint's taper bolt and railing the holy hell out of it from a 10lb maul wont work like it does for outer tie rod ends? (im not concerned about damaging the BJ, since im going to replace them all on my own before the 50N service campain is done...)
You may get a headache from it if you do. These bolts use 19mm nuts instead of 17 mm nuts, so they are substantially more stout. I tried. (Didn't get my 8lb maul out tho'.) What I was suggesting is just a more delicate method of accomplishing the same thing. I just used a bearing puller to put tension on the taper bolt, then just whacked it a couple of times with a claw hammer (NOT a sledge!!). If you use a sledge, you could damage the spindle!:chair: If you use a sledge, you'll need to just tap it. A ballpeen or claw doesn't have enough mass to damage the spindle. |
Good advice and good to know! :D
Is the lower ball joint just as tough to get off as well? |
i had no prob with a pickle fork....i put it in, one good whack and it broke loose. had it all done and back together in about a half hour. thanks for the help guys
(Post 1006924)
Is the lower ball joint just as tough to get off as well? HTH |
| All times are GMT -8. The time now is 06:12 AM. |
