Replacing lower control arm bolts
I'm replacing a control arm alignment bolt on my 87, the previous owner used a bolt and washer.
Should I use grease or anti seize on the bolt surface that way it doesn't seize in the sleeve? I thought I heard anti seize can cause corrosion issues in nasty environments and this is a woods truck.
Boomer8404
May 31, 2016 11:29 AM
Fire4Effect
Jan 11, 2016 06:49 AM
odonnell
Nov 20, 2015 12:33 PM
