Replaced spark plugs in 3vze, now running like ass, thoughts?
All plugs are at 13'ish foot pounds. I do see a power increase in driving, I just had to adjust for idle. I wonder if putting in a much different gapped plug (from .040 to .034) had anything to do with having to adjust the idle. In that case, it would make sense.
I did drop a couple plugs but it was on soft ground. I inspected them and the porcelin wasn't broken. Also, the plug wires are new... Too bad I don't have a rpm gauge, I could see what I'm idling at. I had multiple guys listen, they all say it sounds like a normal idle. Sounds "ok" to me, sounds ok to my mechanic friend...
EDIT: Dupermandave, nah, they are gone.
1 Post
Plug wires are about a month old. I bought the V-Power plugs after reading all the praise they recieved in the other threads. Also left them at stock gap after reading (this is where I'm thinking I went wrong). I'm 100% confident the plugs are in correctly, as in not cross threaded or not in all the way. After installing the plugs the truck ran like trash... if it's not struggling to keep an idle it's completely dying. When accelerating, however, it's almost not noticeable. It also died when I left off the gas to make a turn into my neighborhood... I have also noticed a slight smell of burnt / unburnt gas. What's the first thought that comes into your guys' mind of the potential problem here? Thanks for the help, all.
Keep us Posted
- My Plugs were platinum BTW, thats why I didnt gap mine..I replaced my moms plugs on her 2000 Camry LE but they were also platinum..
#26
Are you truly sure that it is the plugs? You say it struggles to idle but under acceleration it is fine? A plug that is miss gapped slightly should not effect idle to the point of stalling. Do this: while the truck is idling remove the oil cap from the valve cover. Is this how it idles sometimes? If so, it is a vacuum problem.
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
saphirekosmos
06-22-2015 10:26 AM
