Rear wiper ??"s
:con:First, I searched, but didn't really find the answer. Maybe I missed it, for that I'm sorry.
I changed my radio antenna today. While doing so, I had the back open for a little. When I put it up and rolled the window up, the wiper started running. I can't get it to stop. I followed the wiring and stuff, but couldn't find the issue. Any ideas?? Also, since I won't be using it all that often, is there a button or override for the rear window. If I unplug the wiper, I still can't get the window down. Any suggestions? Thanks for your time.:con::con: |
How about a bypass or something, so I can just remove it?
Did you accidentally push the wiper switch on your center console when you were working on your radio? Sounds basic, but I have done that on my 84 4Runner when the key/engine is off, then when I turned on ignition or start the truck the wiper starts to run. It always surprises me. Just a wild guess!
If you unplug the wiper where the top comes off and there is a bolt in the "top bolt switch" hole, the rear window still works. This works on my 86 and 88 with the soft top.
http://i22.photobucket.com/albums/b3...s/IMGP0102.jpg |
I'll probably crawl back and unplug it from the corner and get the back open. Then, try to track down the issue.
I did hit the button while working on the radio and my son was crawling around the truck. After I noticed it running I tried everything I could think of to turn it off. Nothing's worked. Is there more than on rear wiper/fluid switch? Basically looking for a "secret" switch, or possible causes for this issue. Thanks 4runnerx3, what top is that? Cost? |
Maybe the wiper switch on your console was damaged when your son was crawling around in the truck. Might be something to check first. If not, check this link to a site with some troubleshooting hints:
http://www.4crawler.com/4x4/CheapTri...leshootingTips |
Killer Toy Tops
http://www.killertoytops.com/?q=products1 |
