Rear sliding window replacemt for Pickup
Where is a good place to find one? I recently got a '95 Toyota Pickup that is just missing the middle section of the rear window, I believe it's a sliding window. Having trouble finding the part...where is a good place to find it? And is it simple to install?
Thanks in advance. |
Pretty much any junkyard. Don't know how easy it is to replace, as I've never had the pleasure of doing it. I see them all the time at boneyards, though.
Very easy to replace the whole window. A screw driver is all you need. Just push the rubber part out or in and "unzip" the window. If you ever get locked out of your truck very easy to get in thorugh the back window.
I replaced mine with a chunk of plexi-glass.
Just cut it to size and drilled some holes to fit the latch. The plexi is flexible enough to bend and pop into place. It latches just fine. The only problem is that the rear window is actually curved and not flat. It doesn't seal properly. It does, however, make it really easy to get into my truck when I lock my keys in the ignition. Makes for some funny looks in public places. |
rear slider latch
Don't mean to high jack but... Does anyone know where I can find a latch?
I have looked online and can only find one for an 82-88 I also went to my local pick and pull and all the yotas are missing the back window. Has anyone used one from any other makes? I have a 1992 toyota pickup.:bowdown: |
