YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   rear locker (https://www.yotatech.com/forums/f116/rear-locker-114654/)
dijlop May 1, 2007 03:21 PM
rear locker
im lookin for a rear locker for my '94 2wd pu. its mainly on-road driving, so im looking for one that will run open until either it starts to slip and spin free or i flip a switch.
hows this one? http://www.drivetrainspecialists.com...-locker-1.html
bob200587 May 1, 2007 03:26 PM
Man, I'd say since it's just a 2wd get the Detroit tru trac limited slip. I don't see much point in a locker for a truck like yours. You could get an ARB, but still, the wheelin' potential isn't very high for your vehicle, at least not without alot of work.
dijlop May 1, 2007 03:31 PM
u are quite persistent. maybe i should start dissin ur 4 cyl engine? lol
even ur sig is wacked. if the gates are never open, how can u recieve supplys? how about new technology? if we never tried something new, wouldnt that mean we would never advance? or do u think we should just be happy with cancer and aids still rampant and such?
anyways, i was looking for the detroit tru trac and this is what i ended up with.
dijlop May 1, 2007 03:34 PM
whats the difference between the 7.5 in and the 7.5 in ifs?
through the ifs one i found a tru trac link, which showed me this.
http://www.drivetrainspecialists.com...ruetrac-1.html
dlbrunner May 1, 2007 03:45 PM
You do not need to concern yourself with the 7.5 in diff. it is the front diff on a 4wd model.
You have a std 8" toyota differential. unless you swapped something else in there.
I think a LSD might be a better option being you drive a 2wd.
dijlop May 1, 2007 03:49 PM
very helpful. thanks. i'll keep lookin. i tried to get a measurement, and ended up with the only ruler ive ever seen with no real measuring system. very weird. cant even explain it. lol
edit- found it. http://www.drivetrainspecialists.com...duct-2421.html
hows that price and such?
89-4Runner May 1, 2007 04:05 PM
I got my locker (lockright - almost the same thing a lunchbox style locker) from CENTRAL4WD.COM and it was $239 w/free shipping...
dijlop May 1, 2007 04:10 PM
found the one ur talking about and its for the v6 and turbo. i have neither, but nice find regardless.
found the arb locker for $912. lol. that sounds bout right. a bit too much $$$ for my tastes(taste being wallet)
Robert m May 1, 2007 04:24 PM
everything i have read/heard is if you have a 1ton or a 4 speed trans you have an 8''
if you have anything else you have the 7.5
http://www.downeyoff-road.com/Chassi...ents/index.htm
dijlop May 1, 2007 04:28 PM
oiy. lovely. umm. i guess its time to research more. lol. i'll check it all out in the manuals and such 2morrow, and worst comes to worst i'll find a real ruler and just see if i cant figure it out.
fthertime666 May 1, 2007 04:34 PM
2wd, 5 lug axles are a 7.5 inch ring gear, same as ifs front. The tru-trac should fit.
dijlop May 1, 2007 04:39 PM
can i quote u on that one? kinda funny to me, cause i just quoted u asking if i could quote u...:barf:
ovrrdrive May 1, 2007 04:44 PM
If you're planning on running bigger tires eventually you'd be better off to swap in a rear axle from a 4wd truck...
Not only is it stronger and geared better for your big tires (usually 4.10), but replacement and aftermarket parts are a dime a dozen. If you blow the 3rd in it you can get another stock unit for like $150 and you can buy just about any brand or type of locker or LSD you want to...
dijlop May 1, 2007 04:50 PM
i dont plan on going over 30. probally closer to 29's.
the 4wd axles, pricing and install toughness?
fthertime666 May 1, 2007 05:01 PM
um... yeah, you can qoute me:) the axle housing is completely different but the carrier and side gears are the same. AFAIK the actual R&P
gears are incompatible since the drive and coast would be on opposite sides.
MudHippy May 1, 2007 05:13 PM
Here's the link that tells you how to determine for sure what type of axle you have. Your axle code will tell you with the most accuracy. Finding the information plate is simple, it's either in the door jamb or on the firewall behind the engine. If it (axle code) starts with an F, F###, it's a 7.5". If it starts with G, G###, it's an 8". The 5 lug thing is also true. However, the ring & pinion are actually identical with IFS. The same as with 8" gears being the same in fr/rr axles, so are the 7.5".
http://toyota.off-road.com/toyota/ar....jsp?id=274535
bob200587 May 1, 2007 05:20 PM
Wow, someobody's a little pissy tonight....I don't see how "dissin" my 4cyl engine would mean much, seeing as how you have the same motor. I also don't recall "dissin" you at all. You asked, and I gave you my advice. I don't think a auto locker would be a good choice, and an ARB is a little expensive, so I said, consider the Tru trac.
Not going to bother responding to the rest.
fthertime666 May 1, 2007 05:38 PM
dont quote me!
hahahahlol sorry, guess I had my head backwards, confused:think:forgot front and rear drive shafts rotate in opposite deerections
91TPU May 1, 2007 05:42 PM
i agree with this completely...in addition you say your gonna run 30inch tires, but trust me, when i feel as tho your gonna want more...thus the rear 4wd axle will do better for you...
Bunta Fujiwara May 1, 2007 06:32 PM
If you really want LSD, you could swap in a '96-99 Tacoma rear diff, and go with 2WD for similar compound ratios. Don't know if it would bolt right up, but you could consider giving it a try. Again I apologize if somebody has already suggested this, because I only have one browser window open right now.
