Rear Brake Shoes for 1986 4Runner PN 04495-35110 or 04495-35112
#41
not a bad theory. might be correct.
if there is any pitting, you'd need to remove a bit of material via honing. your original cups and pistons would be rendered too small in diameter, and will leak. if you really want to rebuild them, you need to bore and hone, and then match cups/pistons with new bore. if there were no source for wheel cylinders, this would be a good alternative. however, with readily available replacements, rebuilding the originals is not cost effective at this point in time. perhaps in the future, it will be.
wally
wally
#43
this is the tool i use for removing sping "A".
https://www.summitracing.com/parts/o...MobileSwitchNo
#45
I'm not a fan of throwing away "good" parts, but gee whiz, a complete replacement wheel cylinder from RockAuto runs from $21 down to $4!
Yeah, these are aftermarket parts (Toyota runs about $65-$70 at an online dealer), but your originals lasted 31 years. Are you afraid the replacements will only last 25? 15? How long do you think you were driving with your scarred cylinder?
#46
the hook is inserted into the coil portion of the spring. the straight tip is inserted into the slot in the brake shoe where the spring hook end goes. close ends of pliers together, and guide the spring hook into its slot. it takes practice, but i've used the tool on multiple vehicles over more than 20 years.
#47
not on spring A. use the pliers method as described in the post above. the cam action is used where an anchor post is employed - for these, there are usually two springs that attach at the anchor, and the cam tool end will easily slip the spring hooks off. my cj uses this action.
#48
Lessons learned
Lessons learned:
(Searched for "rear brake" and rear brake cylinder" but found nothing so here goes...)
I recently checked and ended up replacing my rear brake shoes. The shoes part was uneventful, although proper tool for removing and re-installing the return/tension spring would have been nice.
After the shoe replacement, left brake cylinder leaked. NAPA carries replacement cylinder for $16. I replaced them at NAPA parking lot. About a week later, the right side cylinder leaked, too. Replaced with NAPA part again without any issues.
LESSONS LEARNED post-mortem (Not much I could have done because truck was 30 years old when I got it):
1) Good idea to flush and refill brake system, including the cylinders and calipers if possible. Dirty / old brake fluid promotes / allows rust in cylinder.
2) Rubber cups keep the cylinder wall that they rub against clean, smooth and free of rust. As shoes get thinner, the rubber cups inside the cylinder
operate farther and farther away from the center of the cylinder. The part of the wall closer to the center of cylinder where the cups do not rub anymore get rusted / pitted. After replacing with new brake shoes the cups and pistons will now operate closer to the center of the cylinder again - right on the rusted wall surface. This will break seal against the wall and cause a leak.
3) Cylinder can be honed, but even if the rubber cups, pistons, and seals and are still in good condition like mine (here) and (here) were, they might be too small for new cylinder bore size. Tools, supplies, and time could cost more than new replacement (and even OEM if you can find it).
4) Always have spare brake cylinder or rebuild tools and supplies readily available when replacing old brake shoes where above conditions apply.
5) This problem may not occur on front disc brakes where brake pads are replaced more often, so cups and pistons are pushed back toward the center of the caliper before rust develops.
#49
LOL! BTW, I'll be driving to Wahweap on Monday, for volunteer clean-up work on Lake Powell. You or other Yota Bros happen to be along this way?
https://www.google.com/maps/dir/San+...8!2d36.9977958
Next time
#50
AVOID bendix brake shoes #PB568
BTW, based on wallytoo's experience as shared on separate thread, AVOID bendix brake shoes #PB568 from rockauto.
"tabs at the wheel cylinder end were too long, and wouldn't allow the drums to fit back on"
