Questions on Adjusting valves!
I don't know where to start, could someone tell me some procedures?
thank you! :D |
Start with "22RE valve adjust" (or 3VZE) in the search field
That should yield a few results :roll: |
thanks [:
or at least remind us which engine you are working on.
sorry ! im working on the 22R-E [x
you need to download the FSM or factory service manual and that will give you some info. do a search for it on hear or google it. i think the valve check info is in the tune up section. it's an easy job: valve cover comes off, rotate #1 to TDC, check valves, rotate #4 to TDC, check valves.
