Question & HELP! Ive searched already!!
Okay truck starts when it wants too? Its got a complete tune-up and replaced AMF. I put in two different new batteries, and yet the battery light is on along with the check engine light? Truck doesnt crank only when it wants it wants too? IM thinking its the battery cables are worn and need to be replaced? Could it be anything else? It has a new alternator, checked it when it was running, and starter. IM doing research as I write to figure out and learn how to perform the code function.
sounds like you may have a short somewhere check your connections for corrosion or looseness (is that a word?)
Hey buddy, heres a couple links to get you going, Good luck.
http://www.4crawler.com/4x4/CheapTri...CheckConnector Here are the codes themselves, post back with your findings http://www.off-road.com/toyota/tech/codes/index.html oh but yes, start simple, check those battery connectors, and check all connections |
Make sure your alternator is chaging I had the same issue and it turned out to be the alt brushes
Originally Posted by olharleyman
(Post 50924353)
Make sure your alternator is charging I had the same issue and it turned out to be the alt brushes
WOW! thank-you all. I just got out of work and read the great info. I was like this close to selling it as is! Only Because this truck is my secound 4x4. I was telling this guy at Autozone about my truck, had it for a YEAR! And I am still working on the quirks here and there, its a 3.0. The owner sold to me as is and gave up on the truck, in my older brother who is in IRAQ. He got paid by the owner to put in the head gasket, alternator, starter. My older brother emailed back from IRAQ and told me to sell it! Im like no I cant Brother its a TOYOTA! ya digg??
that happened to me and it was the battery connectors, hope this helps
