Québec law on lifted trucks
New law in Québec for SUV's and pick-ups :
Max tire size over stock 3" Max mechanical lift 2.5" Max pneumatic lift ( as in contact patch to centerline of wheel ) 1.5" Max overall lift combined : 4.0" Good thing I bought the 33's as I was tempted to do some 35's ! So I'll be doing a 1.5" ball joint spacer with relaxed torsions Lower my body lift to 2" from the 3" that came on truck ( glad for that ) Run my 33's on a 15 x 8 alloy with near stock backspace and Jungle Flares to tuck the wheel a bit. This will be legal enough to avoid issues with the police. I'll be carrying a printed copy of the SAAQ document to show and tell the cops. Sad news for Quebecers, you heard it first on Yotatech ! |
O how I love Oregon
Inches? In Québec? Sacre bleu!
Is this the document to which you refer? http://www.saaq.gouv.qc.ca/documents...f_artisan.html (apparently updated sometime in 2013) |
Oui, hahaha !
Yes the guys just got wind of it on the Quebec forum. Cops are doing their spring safety crackdown and rigs are getting taken off the road in droves. http://www.quebec4x4.com/forum/showthread.php?t=158730 |
Based on these rules, all toyota 4runners/ tacomas are illegal in quebec:
27. A neutral start An automatic transmission vehicle must be fitted with a neutral start which cuts the starter current on all speed selections, except for the neutral (N) or P (Park). A manual transmission vehicle must be equipped with a device for engine start only when the clutch pedal is pressed or when the gear lever is in neutral. |
