YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Problems starting (https://www.yotatech.com/forums/f116/problems-starting-128802/)
DirtNWaterMakeMUD Nov 3, 2007 12:18 AM
Problems starting
Hi, my 86 Pickup w/ 22R engine has a problem starting when it is cold outside. It starts usually pretty quickly when it is warm outside. It just clicks, I can hear it click each time I turn the key but it takes a lot of tries till I finally get her to turn over at all. Whats going on here?
:bang:
superjoe83 Nov 3, 2007 12:21 AM
your battery could be getting weak from the cold, but its probably a combination of the battery and starter contacts
DirtNWaterMakeMUD Nov 3, 2007 12:31 AM
I checked the contacts, they all seem good, the connects arent corroded at all and the battery couldnt be more than a year and a half old but I was kind of thinking maybe the battery although it reads good when its just been running for awhile. I am going to take the battery out and have it tested tomorrow cold, hopefully it reads bad
