YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Plugs (https://www.yotatech.com/forums/f116/plugs-293032/)
elcaminokid69 Jan 16, 2016 04:22 PM
Plugs
Need help. Was replacing plugs on my 92 3.0 all went well till I got to passenger side rear plug. I can not for the life of me get the angle right. Any suggestions or advice appreciated
MudHippy Jan 17, 2016 05:38 AM
That's the one you need x-ray vision for. :jk:
The only advice I have is use a small piece of hose as an extension.
Once you do it a dozen times or so, it gets a little easier. Not much though.
elcaminokid69 Jan 17, 2016 05:43 AM
There is a sort of filter on the firewall above the wheel well I was thinking of removing to get the angle
MudHippy Jan 17, 2016 05:47 AM
That might work.
elcaminokid69 Jan 17, 2016 05:52 AM
Too many hoses in the way. The only thing I can think of is that filter thing.
RJR Jan 17, 2016 04:45 PM
Are you having difficulty getting the socket on to remove the old one, or having difficulty getting the new one started in the threads. If it's the first, a wobble extension or a u-joint in your socket extension will help. If it's the 2nd, MudHippy's advice to put a short piece of vacuum tubing (actually, I think I used a piece of fuel line hose) on the plug and use that to get it started might be helpful. Kind of works like a flexible coupling.
