ok replaced head gasket still oil in radiator( help please)
im stuck between a rock and a hardplace.i have oil or a foam in my radiator but no water in oil plugs look good no water in the cylinder. no exhaust coming through the overflow line.no miss ,[
no overheating [help please |
My 87 4wd, 5spd, xtra cab did that 2 yrs ago and it was a pin hole in the timing chain cover. Mechanic told me the timing chain will wear a hole in the cover on the inside and all the pressure spurts it out into the water chambers.
If it's an auto tranny it could be tranny fluid from the cooler.
