YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   odometer stoped (https://www.yotatech.com/forums/f116/odometer-stoped-115095/)
bear92 May 7, 2007 12:05 PM
odometer stoped
I have a 92 toyota and the odometer has just stopped turning. the truck doesent have a tach but the speedometer still works. any suggestion's? how to fix it. loose wire? any info would help... thanks
ewong May 7, 2007 12:11 PM
mechanical odo or digital?
It sounds like its mechanical... gears busted probalby.
Dont use the trip odo reset when the truck is moving (at least that holds true to VWs)
bear92 May 7, 2007 12:21 PM
thanks .... its mechanical. if it is the gears it that repairable? any info???
