YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   is it normal??? (https://www.yotatech.com/forums/f116/normal-104742/)
david28 Jan 21, 2007 12:42 AM
is it normal???
to smell burning clutch sometimes after just doing a clutch job???
95ToyotaPU007 Jan 21, 2007 01:17 AM
I have never encountered it. maybe you didnt completely remove all the grease residue for the contact surfaces
tc Jan 21, 2007 08:42 AM
Did you get the flywheel turned?
david28 Jan 21, 2007 09:12 AM
i cleaned it with brake cleaner, and no i didnt get the flywheel turned...it looked fine but there where some very light abrasions on it
david28 Jan 21, 2007 09:57 AM
should I have had my flywheel turned?? or is it possible that my clutch isnt engaging or disengaging all the way??
any help would be appreciated
MMA_Alex Jan 21, 2007 10:08 AM
could not be engaging/disengaging all the way. It it recomended that you have the flywheel turned, or replaced in general.
I would try bleeding it, and make sure the pedal is in spec. After that if its still burning you're probably going to have to rip it apart again
