new stop light switch-still no brake lights
need wiring diagram for the brake system in my '92 truck
iamsuperbleeder has a link for the fsm, that will have wiring diagrams.
Do you have your 12 volts coming into the switch??
I am sure you checked the fuse. Did you check if the switch you replaced had indeed failed ?? Did you make sure the new one worked |
