YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Need some input Please???? (https://www.yotatech.com/forums/f116/need-some-input-please-154018/)
swerks Sep 8, 2008 04:41 PM
I installed 1 in. wheelspacers on the front of my 86 4Runner. Do I need to install spacers on the rear to even it out?? This truck will see more on road than off. Does not look to odd without spacers on rear, the stance is a little off. will this cause alignment probs???
fillsrunner4 Sep 8, 2008 04:43 PM
you dont have to do it if you dont think it looks weird. Probably can barly notice I bet. Its not a must thing to do
Scooby098 Sep 8, 2008 05:04 PM
You can barely notice it, dont think it matters much, being running mine like that for awhile tho Im going to get spacers since I can barely stick my hand between the back wheel and the frame.
abecedarian Sep 8, 2008 05:14 PM
where are the pics?
swerks Sep 8, 2008 06:19 PM
Is it safer not running spacers in back or not a issue???
swerks Sep 9, 2008 02:18 AM
:bump:
just a 22re Sep 9, 2008 11:19 AM
why did you need them up front? and it dont mater if your front wheels are 15 feet apart as long as you have all 4 tyres hitting the ground!!!
as for one inch dont mater!!!
swerks Sep 9, 2008 01:08 PM
needed some extra room after ball joint spacer install
