need pics
just wondering if any u guys had 31-10.50-15 on 15x8 rims. reason why b/c i have 15x10 rims and 31-12.50-15 but i was thinking of going to the narrower tire. to try and help on gas ( weight) and there is not a good selection of tires in the 31-12.50-15. i like the way the tires stick out from under the truck with the 15x10. thats why i wanted to see some pics of the 15x8 and 31's also dose anyone know what the ECT button is for on the auto trans
ECT- Electronically Controlled Transmission - gives you different shift points on your transmission. When its on, the shifts will be at higher RPM's.
ECT raises your shift points, so your trans shifts at higher RPM's.
| All times are GMT -8. The time now is 06:00 AM. |
