need help identifying these broken parts
So I'm new to the older Toyota game. Just bought a project 94 4runner 3.0
I'm replacing the head gasket and while taking apart found some broken parts I need help identifying thanks in advance https://cimg9.ibsrv.net/gimg/www.yot...ec715e0982.jpg This is on the water bypass outlet at the rear of the motor. whats that plastic item between the hoses. It has two tabs missing from it one hose wasnt even attached and the other broke off https://cimg2.ibsrv.net/gimg/www.yot...c9865acbd3.jpg Hard too see theres two small rubber hoses that were just cut off and left.they each go to a metal tube that goes down the back of the driver side firewall. Kind of look like they go to the water bypass outlet somehow https://cimg7.ibsrv.net/gimg/www.yot...befa9b3c82.jpg This is the top of the intake manifold. On the right side that small tube with the big nut on the bottom. there was no hose attached to it when removed. Im pretty sure its for coolant but not sure where and what it goes to This is my first gas engine rebuild so kind of a newb. Thanks!!! Can't wait to drive this baby for the first time |
The plastic is a temp actuated vacuum valve for the evap system. TVSV I think is referred to as
Originally Posted by Dennis140
(Post 52277447)
The two headed down driver side fire wall are for rear heater... You should only have a single level console and it looks like a metal tube is missing that they connect to.
Rear heater core could have been leaking and they swapped out tubes to bypass it.
Ok I see they bypassed it with the little black hose between metal tubes lol
(Post 52277453)
Edited: I apologize I did a little research now that I know that they are heater lines and found a fix |
(Post 52277447)
The vertical tube on the intake manifold connects to a water passage under the throttle body. There is another hose on the aft side of the throttle body that connects to the water bypass. |
Originally Posted by scope103
(Post 52277463)
I usually call it the "Thermal Vacuum Valve" (TVV). Here's the part number: 90925-05047 http://www.toyotapartsoverstock.com/...092505047.html Toyota sometimes calls it a "Bimetal Vacuum Switching Valve" (BVSV). Some on this site have repaired them, but the plastic top gets "rotten" with age and repairing it is tricky.
The vertical tube on the intake manifold connects to a water passage under the throttle body. There is another hose on the aft side of the throttle body that connects to the water bypass. so the other hose on the throttle body would go to the TVV hose that I was missing possibly? |
Originally Posted by yamaha73
(Post 52277467)
... so the other hose on the throttle body would go to the TVV hose that I was missing possibly?
https://cimg8.ibsrv.net/gimg/www.yot...e4ccaa328e.jpg |
https://cimg7.ibsrv.net/gimg/www.yot...f4013b20ac.jpg
So what do u guys think of this cylinder toward the bottom. Donso or.... |
