Need help on 2,000 rpm idle and loping
Hi guys,
I had a coolant leak over the last week from the small "J" hose behind the intake plenum so I decided to take it apart and fix with a few other things. I got everything back together and started it up, the only problem is the idle is sitting between 2,000 and 2,200! I took it for a drive around the block to see if it would straighten itself out, it didn't. When I pulled in to the driveway it was loping between 1,500 and 1,700. Here is what I replaced during this project (BTW, it idled fine before): Injector o-rings Injector bushings Fuel rail crush washers Upper intake plenum gasket Throttle body gasket Small coolant hose by firewall Coolant Radiator cap I must have done something wrong in the re-assembly but can't figure out what. Any ideas would be much appreciated. |
