My Turbo manifold upgrade and sds
Old 03-10-2008, 06:41 AM
  #41
saitotiktmdog's Avatar
Originally Posted by Targetnut
You don't necessarily want a continuous progression to max rich. Ideally you want it to stay around 14.7 til til the manifold pressure exceeds what ever you have at normal cruise speed. then once you start to pull more load then you want that progression to come in.
It does stay around 14 while under normal cruise speed. I was referring to under acceleration where you start from low rpms and low boost and then proceed to higher rpm and high boost. Once a speed is reached and throttle is reduced the mixture leans out again under cruise circumstances. It is still not perfect yet. I will keep tweaking as I drive it.
Old 03-10-2008, 07:20 AM
  #42
dcg9381's Avatar
Originally Posted by saitotiktmdog
I run out of road or I hit fuel cut due to boost.
What triggers fuel cut with SDS? What psi is your wastegate setup for?
You should be running as much timing as you can w/o triggering your knock sensor... It'll be interesting to see your timing map.
Old 03-10-2008, 07:31 AM
  #43
I dont hear any knock. My timing is rather conservative I think. Plus the sds system has it set up so that whenever knock is sensed it will automatically retard the timing a certian amount. The sds system allows you to set the sensitivity of the sensor and the amount of retard due to the knock sense. I have the sensor set at 4 I think and the retard value of 6 degrees for knock. I have the fuel cut set for 9.29 psi of boost. I can here the waste gate kicking on so I know it is working. I may need to redisign my downpipe eventually and see if the flow out is keeping it from regulating boost properly. Fuel cut due to map happens around 4000 and above but only under hard quick acceleration. I will be gone for a few days and wont have a chance to do any tuning. When I get back I will look at it some more. Ithink my timing I am going to leave as is for now so I will see about putting that up when I get back.
Old 03-10-2008, 10:58 AM
  #44
dcg9381's Avatar
Can it log when the knock sensor is triggered? My knock sensor will trigger before you begin to hear detonation. I have it hooked up to an LED light - and can use it to write to a log. Logging helps a lot when tuning.
What is your wastegate setup for? (PSI)
Old 03-10-2008, 03:26 PM
  #45
I think there is a display menu that will tell you when knock has been sensed. The waste gate when I baught it was advertised as being set with 6 psi springs and it came with boost controller.
Old 09-28-2009, 11:01 PM
  #46
nhughes's Avatar
Question What the news?!?!?
I'm where you were in mar of 08! timing map yet? fuel map? just want to compare!
Old 11-30-2009, 05:33 PM
  #47
I have not messed with the tuning in a while but Ill see if I can put my fuel values up on here by the end of the week. Also try dcg9831 and tc22r they have helped me out a lot.
Old 12-07-2009, 01:42 PM
  #48
justdifferentials
Just Differentials
06-13-2022 07:40 PM
4.34runner88
02-07-2016 02:24 AM
Lons81
11-23-2015 09:25 AM
Streetrod19772000
09-10-2015 06:22 PM
shalom
09-08-2015 10:02 PM
Quick Reply: My Turbo manifold upgrade and sds
