My BJ spacer/Downey leafs Lift thread....DONE!!
Ok so i'm home sick and extremely bored lol...don't feel that bad so i'm gonna go and put on my BJspacers that came in the mail a couple of days ago...
Just ordered 3.5" leafs from superlift So this is what my lift is going to consist of... *BJ spacers from Toyota of Dallas *Downey 3" leafsprings *Edlebrock Shocks *Diff drop? *Manual Hubs Pics up soon! Please tell me if i'm missing anything...i'm pretty sure i'm not but just in case lol -Ben |
Well maybe I'm missin' something, why diff drop? I haven't a clue why anybody might want to do that. The trade offs I mean. But, I'm Mr. Ground-Clearence, 35's.
the diff drop is so that the cv angles are not so severe because of the added bj spacers
Originally Posted by MudHippy
(Post 50422453)
thanks faubrunner
Oh, trust me I get that, bad day caused by just such phenomena, that's what I meant by trade offs ,sorry.:D
for the BJ spacers....make sure you have a cutoff wheel or at least an angle grinder for the back lip. I suggest a cutoff wheel with an air grinder. Angle grinder was painful/burning.
Originally Posted by chimmike
(Post 50422469)
I waiting patiently for pics! Befores, Afters and durings!!! Hurry some of us can't sleep! HAHA hope it goes good for you.
-=Morphine=- |
Now, that's what I call an effective budget lift. Low cost, and good performance. I tried to convince one of my 1st gen buddies to do that minus the diff drop.
If you are looking for more cheap flex, add lo profile COMPRESSION bump stops. Not the droop stops, in fact you have to shim it up. You should be able to run 33x10.50's with that setup. |
Make sure you reuse the OEM bottom load spring on the new spring pack (I didnt) or the Downey springs will settle right back to stock height. I had to put on extended shackles to maintain the lift after my springs had settled.
Originally Posted by mtrdrms
(Post 50423439)
Oh and i'll put up some pics today after i get out of school |
When you get the stock springs out you will notice that the bottom-most spring is flat and fat. You will need to remove it by removing the bolt that holds the stock pack together. Once you remove it you will need to then dismantle the Downey pack and insert the big spring into that pack before you put it in the truck. It may seem a little high at first but trust me, it will settle quite a bit.
i run the bj spacers with low pro's , i have'nt had any problems with the CV's (still have stock droops)
Originally Posted by norcalsvx
(Post 50423551)
(Post 50423545)
not to hijack it or anything but...
i just did the bj spacer/ cruiser coil lift a week or so ago but forgot to see if i'd need to shim the droop stops. how do i do that and how can i tell if i need to. also where can i find low profile compression bump stops...i already tried looking but couldnt find them. |
Originally Posted by traben27
(Post 50423706)
Originally Posted by deathrunner
(Post 50423585)
I had the downey 3" pack, I did not add the extra leaf on my 4runner. It settled to about 2" of lift after fast running as well as flexing. I think that is enough to even out the truck to the 1.5-2" you get out of BJ spacer. I'd just keep the extra spring on hand, and if it looks to low, then add it back in. Otherise, I think you'll be to tall in back.
(Post 50423720)
Your right but the problem is that the 4runners are too low to begin with so the springs have to level the runner (+1") and raise it (+2") and if the spring settles then we are still too low.
| All times are GMT -8. The time now is 03:18 PM. |
