low rough idling and wont stay running 3.0
I've changed plugs wires cap button coil all that and I was getting power steering fluid sucked into my intake through the vacuum I don't know what is going on with it
First off, was it running prior to any of the changes you made? the only way i could think of getting power steering in the intake is if you have mixed up the hoses from the supply/return hose on the p/s pump with the vacuum hoses that go to the air control valve on the p/s pump. the hose diameters are different but nothing surprises me anymore. heres the FSM link:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/11powerste.pdf |
