YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Long shot conversion. (https://www.yotatech.com/forums/f116/long-shot-conversion-118023/)
lewdlude Jun 13, 2007 05:54 AM
I have the chance to pick up a 81 4WD standard cab pickup for pretty cheap. I am wanting to drop my 92 ext. cab 2WD body on a solid axle frame. I figured with the year and cab difference this won't work, but I figured it was worth a shot. Anyone know for sure if they would line up?
Corbit Jun 13, 2007 06:13 AM
Anything is possible with enough work. There is a write up on Pirate about a 2x4 conversion.
gilby4runner Jun 13, 2007 06:27 AM
:welder: i would say that there will be issue with mounting locations. Nothing a little cutting, grinding, and welding cant take care of.
Stomis Jun 13, 2007 06:38 AM
Yeah your only real problem is shifter and body mounts. You may have to chop a little out of your hole and relocate your body mounts. Nothing a torch, MIG, and couple days cant handle.
